Date/Time: Mon, 13 Jan 2025 02:45:37 +0000
Problem with calculation of commissions in Trade Activity Log
View Count: 846
[2017-03-28 13:19:52] |
phaedonk - Posts: 352 |
Commissions are calculated correctly in the Trades tab, meaning the Running P/L gets adjusted properly when you tick/untick Use Commission and apply. However, the Trade Statistics tab shows a commissions total that is multitudes off. I suspect that commissions for different currency symbols (e.g. Yen) do not get converted. See pics for example |
Private File Private File Private File |
[2017-03-29 05:02:45] |
We will be able to get to this in a few days.
[2017-04-02 01:07:10] |
This will be corrected in the next release.
