Date/Time: Tue, 26 Nov 2024 11:53:11 +0000
tpo value area lines
View Count: 1278
[2013-08-18 03:38:27]
dst656 - Posts: 16
is there a way that i can set up the tpo value area lines to be applied to the current day AND the previous day. i don't have any problems with just the current day but when trying to include the previous day i get lost. i read the instructions and iam still not sure how to set it up. can you please tell me exactly how make the adjustments .
[2013-08-18 06:42:47]
So you want the calculations to cover the last 2 days in the chart?
[2013-08-18 14:12:16]
dst656 - Posts: 16
yes
[2013-08-18 14:14:46]
dst656 - Posts: 16
what i mean by the last two days is the current day and the last day i.e. so let's say for monday the 19 i would want that day and friday the 16 th.
[2013-08-19 23:45:36]
This is not exactly supported. The closest that is available is to set the One Period Only at End of Chart input to Yes. But this is not going to do exactly what you want.
Detailed documentation for this is here:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s158
[2013-08-20 00:21:05]
dst656 - Posts: 16
is there a way to get the value area lines of a tpo chart on to another chart ?
[2013-08-20 02:20:21]
No there is not.
[2014-05-10 05:25:11]
User63769 - Posts: 35
Try using two TPO Value Area Lines studies. One references 0 days back and the other references 1 day back. Change the line colors of the second study to be able to distinguish between the two.
