Date/Time: Mon, 13 Jan 2025 02:38:00 +0000
start / end time not sticky
View Count: 614
[2017-03-28 11:59:10]
olatrade - Posts: 10
new chart without studies start/end time is not sticky
any ideas?
[2017-03-28 16:15:57]
It is not clear what you mean.
However, refer to:
Global Symbol Settings: Setting of Intraday Chart Session Times
[2017-03-31 08:33:45]
i can't figure out what is wrong but every time i change the session time in my chart its going back to the original setting
i checked below settings, they are unchecked
Preventing the Changing of Intraday Chart Session Times
To prevent the Session Times from being changed when the symbol of an Intraday chart is changed, do the following:
Make sure Global Settings >> Symbol Settings >> Apply Intraday Session Times to Intraday Chart is unchecked.
Make sure Chart >> Chart Settings >> Advanced Settings >> Apply Intraday Session Times to Intraday Chart is unchecked.
Date Time Of Last Edit: 2017-03-31 08:43:05
Private File
[2017-03-31 09:08:59]
Here is the relevant documentation for this:
Unable to Change the Bar Time Period for Charts
