Date/Time: Mon, 13 Jan 2025 02:01:30 +0000
Out of Order Timestamps Detected
View Count: 1414
[2017-03-28 09:19:31] |
Adam - Posts: 141 |
i have noticed the following Out of Order timestamps. which is impacting an auto trade system. F.US.BP6M17 1 Min #32 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2017-03-27 23:00:00. Next Bar Date Time: 2017-03-27 21:59:00. Filename: F.US.BP6M17.scid | 2017-03-28 09:07:10 F.US.BP6M17 5 Min #32 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2017-03-27 23:00:00. Next Bar Date Time: 2017-03-27 21:55:00. Filename: F.US.BP6M17.scid | 2017-03-28 09:07:38 setting in screen shot can you advise? |
ghjgjghjghjhg.JPG / V - Attached On 2017-03-28 09:19:23 UTC - Size: 100.73 KB - 281 views |
[2017-03-28 16:59:16] |
We apologize for the delay. Refer to this help topic for instructions: Out of Order Timestamps Detected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
