Date/Time: Mon, 13 Jan 2025 02:50:21 +0000
Alert Condition Formula Question
View Count: 610
[2017-03-28 01:20:20] |
I’m having problems with my alert filters used to color my bars and backgrounds. 1) The filters seem to work on some time frames, but then not on others (i.e. ok with 60m chart, but not ok on the 2m chart) 2) The filters will also seem to work with some markets, but then not with others. (i.e. ok with the NQ, but not ok on the 6E) Here is the code I’m using to create the filter. AND(ID8.SG1>ID8.SG4,ID8.SG3>ID8.SG4,ID9.SG1>ID9.SG2) Where: ID8.SG1 = MACD ID8.SG4 = zero line ID8.SG3 = MACD Diff ID9.SG1 = RSI ID9.SG2 = line at 70 So, here’s what I’m looking for: MACD > 0, MACD Diff > 0 and RSI > 70 Please advise on what might be happening…thanks! Most likely the issue has to do with the Value Format of the referenced studies. Refer to: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
