Date/Time: Mon, 13 Jan 2025 02:07:39 +0000
Feature in the quoteboard
View Count: 744
[2017-03-28 00:06:16] |
Kinobe - Posts: 86 |
Hi Would it be difficult to add a drag&drop feature in the quoteboard as shown in the video in order to put a symbol any where very fast? if too complicated to implement, at least a keyboard shortcut cut&paste feature would be great. right now, I need to write the symbol, if I want to move up the symbol because I want to re-order several symbol in a priority order at the opening, I need to delete them and write them again to the new place which takes much time. thank you. |
Attachment Deleted. |
[2017-03-28 04:16:09] |
Drag-and-drop is out of the question. Cutting and pasting is and always has been supported in all edit boxes related to the Quote Board where a symbol is entered. If you have a problem with this, clear any keyboard shortcuts you set up which are interfering with them: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) You simply should have no trouble with this whatsoever. The proper way to move symbols up-and-down is through Settings >> Set Symbols on the Quote Board: Getting Quotes: Setting Symbols You should also be aware for some users, that drag-and-drop functionality is something which is a nuisance and can and does cause very serious problems. This is especially true with touchscreens where accidental drag-and-drop operations can be so easily invoked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-28 04:21:12
[2017-03-29 00:36:09] |
ok I ve just found out how to cut and paste. The things that I missed was to enter in the cell of the quote board and afterward make the cut&paste. Could it be easy for you to implement a shortcut to move up or down a symbol in the quoteboard? thank you |
