Date/Time: Mon, 13 Jan 2025 02:40:51 +0000
data activate request
View Count: 600
[2017-03-27 22:18:47] |
User185675 - Posts: 3 |
Hello I am trying to use trial demo with AMP Futures however the CQG web API is not enabled for my trial for sierra.
[2017-03-28 00:30:10] |
Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
