Date/Time: Mon, 13 Jan 2025 02:09:35 +0000
MIT ORDERS
View Count: 661
[2017-03-27 18:08:54] |
User82615 - Posts: 106 |
HELLO I'M TRYING TO PROGRAM A TRADING SYSTEM THAT SENDS AN MARKET IF TOUCHED ORDER WHEN THE BAR IS CLOSED AND THE MARKET IF TOUCHED PRICE WILL BE THE LOW OF THE BAR , BUT OF COURSE I WOULD LIKE THAT AT THE NEXT BAR IF THIS ORDER HAS NOT BEEN TRIGGERED THIS ORDER WILL BE CANCELLED AND THEN SEND A NEW MIT ORDER AT THE LOW OF THE NEXT BAR. CAN THIS BE PROGRAMMED? IF SO IS IT NEEDED AN OCO-MIT TYPE OR ORDER ? IS THERE AN EXAMPLE WHERE HOW TO PROGRAM THIS? THANK YOU VERY MUCH IN ADVANCE |
[2017-03-27 18:14:40] |
Yes this can be done. You would just use a market if touched order. There is no example for this. We can refer you to a programmer that can help. Let us know if you would like us to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-27 19:02:19] |
YES PLEASE COULD YOU REFER ME ANY PROGAMMER THAT COULD HELP ME TO PROGRAM THIS? THANK YOU VERY MUCH IN ADVANCE |
[2017-03-28 02:02:43] |
We have. They should be posting here with further information. If you do not hear from them within a few days, let us know.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-28 02:02:55
[2017-03-28 05:47:06] |
Edge Player Trading - Posts: 9 |
Hi. I was asked to get in touch with you regarding your project. Please send your email address to Jim@SierraChart.com along with any additional information about your requirements.
