Date/Time: Mon, 13 Jan 2025 05:54:31 +0000
My DOMs are bugging out
View Count: 741
[2017-03-27 14:16:34]
Dmac - Posts: 25
DOMs acting weird, the center scrolling down of the screen. Attached is a brief vid and image of my scroll settings.
attachmentIMG_0597.MOV - Attached On 2017-03-27 14:15:40 UTC - Size: 16.88 MB - 278 views
imageIMG_0598.JPG / V - Attached On 2017-03-27 14:15:46 UTC - Size: 100.46 KB - 265 views
[2017-03-27 16:37:56]
Select Chart >> Reset Scales.
Let us know if that solves the problem.
[2017-04-04 12:42:26]
Dmac - Posts: 25
An Update: when currrent price on the DOM is scrolling off the screen, Select Chart >> Reset Scales does not correct that action. Only when the DOM ceases to scroll, then Chart >> Reset Scales brings current price back into view and to the center of the DOM.... Until the DOM begins to scroll away again. Which is happening repeatedly now with my DOM for /GCM7.
[2017-04-04 16:48:31]
Follow the instructions here to open the Scale Settings window:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowMainPriceGraph
Set the Constant Range Scale Mode to "Manual Mode".
We will work on the issue today.
There might be a problem with the way this is implemented on the Trade DOM. We need to verify that only the last trade price is being used and as soon as Reset Scales is selected, this should immediately cease all movement.
Date Time Of Last Edit: 2017-04-04 16:49:36
[2017-04-05 07:49:55]
We have this problem now resolved. Update to the latest prerelease following these instructions:
[2017-04-05 13:26:56]
Dmac - Posts: 25
Installing now. Appreciate your attention to this.
