Date/Time: Mon, 20 Jan 2025 04:10:09 +0000
For Continuous Futures Contract Charts use which type ? most comon
View Count: 1254
[2017-03-27 11:18:47] |
FH87 - Posts: 43 |
Most people use which type ? I need similar like those CFD Date Rule Rollover Volume Based Rollover Date Rule Rollover, Back Adjusted Volume Based Rollover, Back Adjusted |
[2017-03-27 17:45:00] |
It depends upon the symbol of the chart. Tell us the symbol of the chart. Also refer to: Continuous Futures Contract Charts: Using Date Rule Rollover or Volume Based Rollover? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-28 21:08:50] |
FH87 - Posts: 43 |
that link state Currency and index use Date Rollover Commodity use Volume Rollover |
[2017-03-28 22:39:10] |
Yes that is true.
[2017-11-28 20:12:19] |
User103672 - Posts: 1 |
Can Sierrs Charts provide continuous unadjusted charts? If so how do we access them? Thanking you in advance |
[2017-11-28 20:41:00] |
Yes of course. Just follow through the instructions here: Continuous Futures Contract Charts And do not use one of the back adjusted Continuous Futures Contract options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-28 20:42:40
[2018-05-28 00:55:34] |
You need to use this particular Continuous Contract option: Continuous Futures Contract Charts: Continuous Futures Contract - Date Rule Rollover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
