Date/Time: Mon, 13 Jan 2025 02:57:16 +0000
sc.TitleBarName / sc.CustomTitleBarName - issue
View Count: 603
[2017-03-27 08:44:37] |
Marek F - Posts: 244 |
In the version 1531 there is an issue with sc.TitleBarName and sc.CustomTitleBarName : MyStudy.cpp:963:22: error: 'struct s_sc' has no member named 'CustomTitleBarName' PL, sc.CustomTitleBarName.GetChars(), Hour, Minute );
MyStudy.cpp:1078:22: error: 'struct s_sc' has no member named 'TitleBarName' PL, sc.TitleBarName.GetChars(), Hour, Minute ); If i back to the version 1527, there is no issue with sc.TitleBarName. |
[2017-03-27 09:07:46] |
This is the variable you need to use: sc.CustomChartTitleBarName These other names are no longer supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
