Date/Time: Mon, 13 Jan 2025 02:58:46 +0000
Using combined records volume in time and sales for other indicators
View Count: 914
[2017-03-27 03:18:57] |
User727214 - Posts: 1 |
Hello Support I trade the SPI200 and I use the combine trades feature to see possible larger size trades. I use "combine trades with same time and price" I have attached a screen shot of some of todays time and sales Is it possible to use the larger combined volume as an input to other indicators? I wanted to have a cumulative delta or ask/bid volume difference bars that only use volume data that is say larger than 5 using the combined trades higher values I have tried the volume filter under chart settings but this only uses the normal volume prints from what I can see Thanks Jonathan |
SPI Combined Records Volume.png / V - Attached On 2017-03-27 03:04:30 UTC - Size: 87.82 KB - 278 views |
[2017-03-27 05:03:38] |
No, this is not supported.
