Date/Time: Mon, 13 Jan 2025 02:40:16 +0000
Linker error when using GDI
View Count: 1248
[2017-03-27 01:28:34]
Usermb - Posts: 126
Using 1531 on Windows 10 x64.
Trying to compile the default GDI example (GDIExample.cpp) leads to:
-- Starting build of Custom Studies Source files: GDIExample.cpp. -- 03:04:37
C:\windows\system32\cmd.exe /C "C:\SierraChartScan\ACS_Source\VisualCCompile.Bat"
C:\SierraChartScan\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
GDIExample.cpp
Creating library GDIExample.lib and object GDIExample.exp
GDIExample.obj : error LNK2001: unresolved external symbol __imp__CreateSolidBrush@4
GDIExample.obj : error LNK2001: unresolved external symbol __imp__DeleteObject@4
GDIExample.obj : error LNK2001: unresolved external symbol __imp__Rectangle@20
GDIExample.obj : error LNK2001: unresolved external symbol __imp__SelectObject@8
C:\SierraChartScan\Data\GDIExample.dll : fatal error LNK1120: 4 unresolved externals
-- End of Build -- 03:04:49
All other studies compile fine, in some of my other studies I even use Boost, and still no problem, all compiles fine.
[2017-03-27 02:38:02]
User553714 - Posts: 184
I added the line below to the top of the DLL and got it to compile but in my case there was no box drawn?
#include <fcntl.h>
On the little research I did this is for the Windows file descriptors like "_O_TEXT" and is not included in SC header file (not in scstructures anyway).
[2017-03-27 02:53:10]
This will be resolved in the next release which we will have out tomorrow.
[2017-03-27 18:32:53]
Usermb - Posts: 126
Thanks a lot, you guys rock, really great processes you've got there!
