Date/Time: Mon, 13 Jan 2025 07:41:32 +0000
opening Range study?
View Count: 1648
[2017-03-27 00:37:19] |
User157806 - Posts: 71 |
Is there a way you can use a study to draw a time box for the first 30 minutes opening range? a customer has the study in CPP form, but they can not import it. Any suggestions?
[2017-03-27 16:58:08] |
Yes this can be done with the High/Low for Time Period study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s246 For the two Subgraphs of this study set them to Fill Top and Fill Bottom respectively: Chart Studies: Fill Top (ACSIL: DRAWSTYLE_FILL_TOP) and Fill Bottom (ACSIL: DRAWSTYLE_FILL_BOTTOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-28 00:09:34] |
Appreciate the response thank you.
[2017-04-19 14:16:17] |
cmet - Posts: 576 |
How can I plot opening range based on something other than time? Specifically, first bar of the session. |
[2017-04-19 17:06:52] |
When using the Initial Balance study or the High/Low for Time Period study, you need to specify the time range. There is no other way. Refer to: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=313#High_Low_For_Time_Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
