Date/Time: Mon, 13 Jan 2025 02:58:12 +0000
Ichimoku Cloud
View Count: 742
[2017-03-26 22:34:54] |
Executor - Posts: 40 |
Im using Senkou Span A and B In draw style menu for Span A I chose: Trans. Fill Top In draw style menu for Span B I chose: Trans. Fill Bottom When selecting these options nothing is displayed. But when choosing: In draw style menu for Span A I chose: Fill Top In draw style menu for Span B I chose: Fill Bottom The cloud is displayed. I would really like the cloud to be transparent |
[2017-03-27 18:18:48] |
Check the Transparency Level. Refer to: https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#TransparencyLevelForFillStyles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-27 21:24:25] |
Thanks, issue is now resolved
