Date/Time: Mon, 13 Jan 2025 02:59:04 +0000
Updated To Version 1531 -- Charts Taking FOREVER To Load
View Count: 572
[2017-03-26 21:16:02] |
User29662 - Posts: 76 |
It used to take a minute or two for my charts to load with all the indicators calculated...now its taking forever...mostly the VWAP calcs...
[2017-03-26 21:19:26] |
There are definitely no known performance problems in newer versions. Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often If you know it is the Volume Weighted Average Price study causing the problem, then tell us the particular Input settings you are using with that study and also give us the exact name of the study. There must be some issue with the settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-26 21:20:22
[2017-03-26 21:28:49] |
I just upgraded and changed absolutely nothing else so I know it was the upgrade that made the difference. What a pain. Now I have to start troubleshooting unnecessarily. Is there anyway to go back to my previous version, that worked a lot better? It was a Version in the 1400s but not sure which. Anyway to find that out?
Date Time Of Last Edit: 2017-03-26 21:31:36
[2017-03-26 21:34:11] |
You can go back to a prior version. Refer to: Software Download: Software Rollback Procedure But you should take the time to see what the issue is. Overall newer versions provide higher performance so there must be something specific and unusual which is causing the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-26 21:35:00
[2017-03-26 21:36:31] |
I will figure it out at some point but not in the mood to fiddle right now. Thanks!
