Date/Time: Mon, 13 Jan 2025 02:40:40 +0000
TimeZone matching for Historical and Intraday - Open, high, low, close
View Count: 906
[2017-03-26 19:00:03] |
Trint - Posts: 115 |
Hi, I've tweaked my system and finding I rely more on the need to have Daily and Intraday times having to match for Historical prices (i.e for instrument ^EURUSD). Does someone on Sierra have a configuration setup they are willing to share..? I've tried using -2 GMT but then run into having the Sunday Cradle and I'm not sure what exchange time the original Historical Prices are based on. Thanks for any help. Trint |
[2017-03-26 20:07:17] |
Do not use the Forex symbols with a ^ character. Use EURUSD instead. These symbols are 24 hours and start a new day at 17:00 US Eastern time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-26 20:26:06] |
Thanks for that Sierra but I really rate the ^ instruments as its the same data used by Barchart and my system seems to accurately trade well with these. Although I haven't tested the non ^ symbols like EURUSD (and I'll backtest) is the data as high a quality, if not more so, than the ^ instruments. I think I read somewhere that you do use unfiltered data for various markets... CQG is another I like.
[2017-03-26 20:29:59] |
We do not know what is meant by "high quality" data for cash Forex markets. The symbols without the ^ characters are derived from FXCM data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-26 20:30:14
[2017-03-27 06:28:13] |
I just find the ^ symbol data a lot 'cleaner'. See the attached as an example. Were you in discussions this year about bringing real-time LMAX data on board....for everyone and not just those with LMAX accounts |
Screen Shot 2017-03-27 at 07.25.00.png / V - Attached On 2017-03-27 06:28:04 UTC - Size: 97.6 KB - 254 views |
[2017-03-27 17:44:14] |
The LMX data will come, but that may still be a few months away.
