Date/Time: Mon, 13 Jan 2025 02:48:59 +0000
Problems running Sierra Chart
View Count: 1766
[2017-03-26 16:27:18]
Camila - Posts: 21
Hi
I have open a free trial account with Sierra Charts and I want it to be connected to a sim account I have in Stage5 trading. I already did the download and did the DTS connection. However, Sierra Charts will not open.
I did the installation on a folder named "SierraCharts2" as I already have Sierra Charts running with an account I have with Infinity Futures. However I want to close this Infinity futures account and move everything to Stage5 trading,
The problem is I am not able to open Sierra Charts.
I am sending the message log for you to analyse
thank you very much
Camila
[2017-03-26 22:27:29]
The problem is you are unable to connect to the Gain Capital FIX server. The reason is explained here:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ServerAvailability
These are the relevant messages:
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2017-03-26 12:27:44
GAIN Capital FIX Trading socket (44) | Creating socket. | 2017-03-26 12:27:44
GAIN Capital FIX Trading socket (44) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-26 12:28:05 *
GAIN Capital FIX Trading socket (44) | Initiating close of socket by core. | 2017-03-26 12:28:05
Although you should be able to connect now.
Date Time Of Last Edit: 2017-03-26 22:28:00
