Date/Time: Mon, 13 Jan 2025 02:43:59 +0000
Horizontal Ray cut off
View Count: 740
[2017-03-26 15:46:48]
CrunchFX - Posts: 13
I see there is away to cut off the Horizontal ray at certain locations is there a way to make it cut off automatically if price crosses a horizontal Ray. I dont see options in tool config.
[2017-03-27 18:11:18]
You can only manually cut a drawing. Refer to:
Chart Drawing Tools: Cut a Drawing
