Date/Time: Sun, 12 Jan 2025 23:59:15 +0000
day delta line on range bars chart
View Count: 766
[2017-03-25 10:10:13]
olatrade - Posts: 10
hi,
i'm trying to get a cumulative delta line for the day on my range bar chart
i cant figure out how to do that.
i don't want cumulative delta per bar but cumulative for the day
in addition i want a chart with cumulative delta for each price level (during a session)
is this possible?
thanks for the help
[2017-03-25 10:56:22]
You need to use the Cumulative Delta Bars study. Refer to:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s292
The closest that is available is to use the Volume by Price study and set it to display the difference between Ask Volume and Bid Volume. Refer to:
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php
[2017-03-25 11:53:50]
thanks. i ended up by using ask/bid volume difference bars (hidden) and cumulative sum of study, this gives a result of green above 0 and red below 0
regarding cum delta per price im almost there
i need the profile at the right and price left of it. (now its overlapping)
is that possible?
see https://www.screencast.com/t/RLL8UWsJ
thanks
[2017-03-25 12:25:11]
found it
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#CreatingSpaceOnRightSideOfChart
