Date/Time: Thu, 01 Oct 2026 16:29:19 +0000
Create a extending rectangle or rectangle in ascil code
View Count: 5649
[2017-03-24 15:30:28]
User210074 - Posts: 63
Do you have a function to draw a rectangle or extending rectangle with 4 or 8 values ?
//string Retangle(Double BDA, double BPA, double BDB, double BPB, double EDA, double EPA, double EDB, double EPB){
/*string Resultat {"...."}; return Resultat;*/
int main(){
double BeginDateA, BeginPriceA, BeginDateB, BeginPriceB;/*<-Value for start Rectangle or Extending Rectangle*/
double EndDateA, EndPriceA, EndDateB, EndPriceB;/*<- Value for end rectangle*/
//string CreateRectangle{};
//CreateRectangle = Rectangle(BeginDateA, BeginPriceA, BeginDateB, BeginPriceB, EndDateA, EndPriceA, EndDateB, EndPriceB);
imageextendingRectangle.PNG / V - Attached On 2017-03-24 15:28:58 UTC - Size: 62.84 KB - 715 views
imageextendingRectangle1.PNG / V - Attached On 2017-03-24 15:29:12 UTC - Size: 78.72 KB - 697 views
[2017-03-24 17:32:11]
Refer to this page to use Drawing Tools from ACSIL:
http://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html
[2017-03-27 12:22:03]
I would like to draw a extending rectangle.
int Transparency_Level = 60;
int Rectangle_Line_Width = 1;
int UniqueLineNumber = 0;
s_UseTool Tool;
Tool.Clear();
Tool.ChartNumber = sc.ChartNumber;
  Tool.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
   Tool.LineNumber = UniqueLineNumber + sc.Index;
Tool.BeginDateTime = sc.BaseDateTimeIn[sc.Index];
   Tool.BeginIndex = sc.Index;
   Tool.BeginValue = sc.Low[sc.Index];
   Tool.EndIndex = sc.Index;
   Tool.EndValue = sc.High[sc.Index];
   Tool.Color = RGB(0,200,200);
   Tool.TransparencyLevel = Transparency_Level;
   Tool.LineWidth = Rectangle_Line_Width;
sc.UseTool(Tool);
I tried this, but I have the following error message:
-- Starting build of Custom Studies Source files: sc_Test_Tools_Extending_Rectangle.cpp. -- 14:00:12
C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat"
C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
LINK : fatal error LNK1104: cannot open file 'C:\SierraChart\Data\sc_Test_Tools_Extending_Rectangle.cpp.dll'
-- End of Build -- 14:00:15
Can you give me an example of drawing an extending rectangle in code.
Sorry, I'm lost.
[2017-03-27 17:17:56]
There is no error in the code.
Do not use a . at the end of this filename.
This means that the DLL file is locked.
Refer to:
Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code
[2017-03-31 03:45:29]
I do not find the function that allows to put the label of the price : "Center Price Labels On Level"
I test
Tool.TextAlignment = DT_TOP|DT_RIGHT|DT_VCENTER;
/*I tested all possible combinations( DT_TOP, DT_VCENTER, DT_BOTTOM, DT_CENTER, DT_LEFT, DT_RIGHT ) , the function is not there ?*/
I can not run the function "Tool.FontSize"
Tool.FontSize = 8;/*For 8px, or x px*/
Date Time Of Last Edit: 2017-03-31 03:56:09
imageText_Rectangle.PNG / V - Attached On 2017-03-31 03:40:12 UTC - Size: 17.05 KB - 591 views
[2017-04-03 06:09:54]
There is not a way to control "Center Price Labels On Level" from ACSIL.
The font size is controlled through the Global Chart Drawing font:
https://www.sierrachart.com/index.php?page=doc/Tools.html#ChartDrawingText
