Date/Time: Mon, 13 Jan 2025 02:10:08 +0000
Three questions
View Count: 665
[2017-03-24 04:21:24] |
aydex - Posts: 110 |
Hi 1. I would like to see candlesticks with black bodies, but also would to have the traditionally colored bodies available They would look like the hollows of the Graph Draw Type "CandleStick Bars Hollow", with black filling. 2. With the curent price on the chart, where is the switch to draw a line across at that price? 3. With a basic indicator, like MACD, is there a way to have that macd graph drawn only at bar close, and not have it update for every new price? thanks j |
[2017-03-24 18:29:44] |
1. All of this can be controlled through the Graphics Settings window: http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html You may want to set the settings for an individual chart rather than globally. 2. Use this study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s123 3. No, this is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-24 19:43:05] |
Sawtooth - Posts: 4149 |
You could use the Spreadsheet Study study to block the display of a study in the current bar.
[2017-03-28 11:43:37] |
Regarding #1 Please confirm that being able to switch back and forth from a (custom made) single color, filled "hollow body" to the standard multicolored "Candlestick bar" cannot be done without going in and tweaking the Graphics settings at each switch. I was hoping I could, for instance, define one of the Menu>Chart>Graph Draw Type's dropdown options, so a quick switch was possible. |
[2017-03-28 16:27:46] |
The only way to do this, is to set the colors in the Graphics Settings individually for two different charts and then switch between those charts. Refer to: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
