Date/Time: Mon, 13 Jan 2025 02:46:53 +0000
[User Discussion] - Formula - Reference previous # of bars
View Count: 1632
[2017-03-24 01:51:29]
User104854 - Posts: 457
Is there a simple way that I can use a formula where, for instance, I'd like the low of the current bar to be lower than all of the previous 10 bars?
[2017-03-27 14:45:32]
Hi. I didn't get a response on this. Is this possible or do I have to reference each individual bar? Again I want the alert to trigger when the current bar low is lower than the previous 10 bar lows. Thanks.
[2017-03-27 16:54:50]
mkata - Posts: 103
You could use the Highest/Lowest over N-Bars study set to length of 10 to show when the low breaks lower.
[2017-03-27 16:57:06]
Sawtooth - Posts: 4149
You'll have to reference each individual bar because you cannot reference a range in Simple Alerts formulas.
For example, this formula L<MIN(L[-1]:L[-10]) returns the same as L<MIN(L[-1],L[-10])
So use this:
=AND(L<L[-1],L<L[-2],L<L[-3],L<L[-4],L<L[-5],L<L[-6],L<L[-7],L<L[-8],L<L[-9],L<L[-10])
[2017-03-27 17:23:52]
Great! That helps. Thank you for the responses on this.
[2017-03-27 19:08:53]
With simple alert formulas there is not the ability currently to specify data from multiple bars as a single range. Each bar needs to be specified individually.
