Date/Time: Mon, 13 Jan 2025 00:06:27 +0000
New computer
View Count: 578
[2017-03-23 22:35:22] |
Marek F - Posts: 244 |
I'm going to purchuse a new computer. Is there any significant difference for Sierra Chart with processors: 4 physical cores versus 2 physical cores with 2 logical cores per physical ? |
[2017-03-23 22:40:09] |
You definitely want 4 actual CPU cores.
