Date/Time: Sun, 12 Jan 2025 23:35:12 +0000
Can't connect to data on 2 PCs at same time
View Count: 606
[2017-03-23 18:00:52] |
User150371 - Posts: 70 |
Hi, I have SC on 2 separate PCs, with CQG data. Each connects to the data feed individually with no issues. But when I try to connect the second one, the data feed on the first immediately disconnects, then both keep attempting to connect, without success. I have tried this using both FIX and WebAPI feeds, but the result is the same. I thought it was no problem to have 2 separate versions of SC on different PCs. Am I wrong in this ? Thank you. |
[2017-03-23 18:53:21] |
This is a limitation of CQG. Contact your broker about this.
