Date/Time: Sun, 12 Jan 2025 23:48:41 +0000
sierrafutures.com
View Count: 847
[2017-03-23 17:04:32] |
phaedonk - Posts: 352 |
Stumbled onto this site today and was surprised by the name and, furthermore, the exclusive suggestion of Sierra Chart as a platform. I see that it is an IB for Dorman, but after a search in the NFA site it doesn't seem to be a company, just a "doing business as" for a PATEL FUTURES LLC. Just thought I'd let you know, if you aren't aware already. EDIT: I see that the company is mentioned in your site, in the CQG page, so I guess you are aware. Date Time Of Last Edit: 2017-03-23 17:08:58
[2017-03-23 17:14:53] |
We are aware of this broker. We are removing them. The NFA has taken action against them and they are effectively out of business.
[2017-03-23 17:18:51] |
Yeah, figured you wouldn't be happy with your name being used like that.
[2017-03-23 17:32:05] |
Yes not good but not much we can do.
