Date/Time: Mon, 13 Jan 2025 02:19:15 +0000
Horizontal Lines messed up
View Count: 695
[2017-03-23 13:47:51] |
User299392 - Posts: 216 |
I cannot enter value for line one because there sits a boolean value now. Please check. |
[2017-03-23 17:12:49] |
We apologize for this. We are fixing this now. This is a study we are working on but have not yet tested the changes.
[2017-03-23 17:33:49] |
Humble 2 cents here - I never saw any notes for newer stuff that trickles in through releases. Like I definitely never saw the change around this in the release notes. Another one to cite you an instance is - Advance Settings 3 included in the CHart Settings - never saw that either. Ideal world, it should be both in release notes and also in the documentation. In the least, in the release notes - please. PS: Somebody like me tends to stay on top of the pre-releases as well and update that too and invariably I never find release notes for pre-releases. Understood why not; but then it creates a gap. Hope I am clear and despite so - let you prevail. 3rd cent # Hire somebody like me who would love to update all your notes and other communications. |
[2017-03-28 21:07:19] |
Any luck fixing this?
[2017-03-28 22:38:48] |
Yes this has been resolved. Update to the latest prerelease with Help >> Download Prerelease.
[2017-03-29 13:18:02] |
This is still a problem. The first draw style gets copied for the rest of the lines down below. Not good. Please check. |
[2017-03-29 17:01:43] |
Go to the Input settings for the Horizontal Lines study: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies Make sure this input: SetAllSubgraphsToBeSameAsFirst is set to No. We are going to put out a new version to ensure that this input is set to No when updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
