Date/Time: Mon, 13 Jan 2025 00:09:46 +0000
Bid & Ask Depth Bars
View Count: 1044
[2017-03-23 13:03:58] |
User99934 - Posts: 227 |
When opening two instances of Bid & Ask Depth Bars on the same chart, with the settings: (Ratio, Time & Sales, 10) and (Ratio, Time & Sales, 3) I get the same output.
[2017-03-23 18:29:32] |
Yes that does make sense. Refer to the documentation for the study Inputs here: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s213 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-23 18:31:42] |
Do you think its correct to get the same output with different inputs?
[2017-03-23 18:45:30] |
Yes because the input for the number of market depth levels does not apply to Time and Sales data. This is what the documentation explains and it is well written.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-23 18:45:50
