Date/Time: Sun, 12 Jan 2025 23:30:41 +0000
Get Lowest Function
View Count: 724
[2017-03-23 01:11:25] |
Johnny - Posts: 99 |
Hello, is there a way to calculate the lowest value of an array in ACSIL excluding all the zero values?
[2017-03-23 03:05:44] |
Just iterate the array elements from 0 to the current index and check for the lowest value and exclude zeros. This is all.
[2017-03-23 17:51:44] |
I would need to do this a lot of times and I need to save space, I was looking for an ACSIL function that could do this.
[2017-03-23 18:58:10] |
You just need to create a function to do this. Refer to: C++ Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
