Date/Time: Sun, 12 Jan 2025 23:51:45 +0000
Chart trading
View Count: 606
[2017-03-22 23:37:15]
User556034 - Posts: 5
Hello , I am new to the SC platform , but have spent a good deal
of time experimenting with it and reading the documentation .
Below are some questions / problems that I could not resolve on my own.
Thanks.
Question 1 )
With 'Trade' -> 'Chart Trade Mode On' , I can right click on
the chart , select a trade action , say 'Sell Limit' , and
a 'Sell Limit' paired with a 'Stop'order above and a
limit order below will appear on the chart and on the DOM .
However , the 'Use Attached Orders' checkbox on the
Trade DOM is unchecked .
In addition , this particular bracket configuration is
not a configuration that I have saved with my trade DOM.
When I trade from the DOM with the 'Chart Trade Mode On' ,
everything works as designed , this problem only occurs when
trading from the chart.
Am I missing configurtion of some sort .
Question 2 )
I am using the 'Current Price Line' study.
When I use the scrollbar to scroll to the left in the chart ,
the price box in the price boarder rolls up and down as it
tracks the close price of the most right visible candle in the chart.
The 'Current Price Line' , however , does not track the
chart as I would have expected .
The 'Current Price Line' study appears to only be
concerned with the last price traded and doesn't
move from that price .
Are there any configuration changes I can make or
is there another study that allows for a horizontal
line to track the close of the most right visible candle
in the chart in unison with the price box ?
[2017-03-23 09:41:59]
1. You must be looking at the wrong Trade Window. Refer to:
https://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying
2. There is no study that does this, and inherently it is difficult for a study to do this. It would not work well.
