Date/Time: Sun, 12 Jan 2025 23:35:18 +0000
Pivot Points - Daily Formula Type 21
View Count: 1432
[2017-03-22 22:58:41] |
monk - Posts: 13 |
Re: Study: Pivot Points - Daily Formula Type 21 Could you add another Pivot Level to the Formula Type 21. Could you add .236 (Fibonacci) as both Resistance and Support? Also, add .50 level. Thank you. Extracted from the Sierra Chart documentation page...
If you require a Pivot Point lines formula that is not listed here, then contact Sierra Chart support. They are easy for us to add. Pivot Points - Daily Formula Type 21 Pivot Point (PP) = Tomorrow's Open Resistance Level 0.5 (R_5) = PivotPoint + (High - Low)*0.382 Resistance Level 1 (R1) = PivotPoint + (High - Low)*0.618 |
[2017-03-23 04:33:16] |
This could only be implemented as a new formula. It will be Formula Type 27.
