Date/Time: Sun, 12 Jan 2025 23:54:28 +0000
Refresh Issue with Relative Volume Indicator
View Count: 1117
[2017-03-22 19:14:18]
drywater0 - Posts: 85
SC Support,
As can be seen at the bottom of the attached image, the Relative Volume indicator on my 5m ES chart is not updating.
http://www.sierrachart.com/image.php?Image=1490209533715.png
I am using the data feed from IB but do NOT think this is the issue because:
1) A custom indicator called RelVolume that does the same calculation is updating continuously as seen in the middle of the screenshot.
2) The price for ES is being continually updated.
3) Volume for my ES 1m chart is updating fine(no screenshot attached).
Please note that if I access the study menu and select any random indicator (does NOT have to be Relative Volume) and hit apply, this action seems to correct the problem as the missing data immediately appears.
http://www.sierrachart.com/image.php?Image=1490209582604.png
Hence, the problem seems to be that the indicator is not updating continuously and instead requires a "manual refresh".
Many thanks in advance for your guidance
[2017-03-22 19:37:33]
33818 - Posts: 30
I was having the same problem a few weeks ago. That said, I'm using Sierra's data. Updating to the latest version of SC fixed it for me. Good luck.
[2017-03-22 19:39:07]
This was already resolved. Update Sierra Chart to the current version following these instructions here:
http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate
