Date/Time: Sun, 12 Jan 2025 23:46:51 +0000
tradelog output data format
View Count: 1121
[2017-03-22 16:10:08]
User30743 - Posts: 365
hi, i would like to ask why i got different format of output data from tradelog (date and time format is missleading) - i use sierra chart on more than one pc and i export trade log from each and put in the excel file to have one single statistic
- but the datas are not in the same format (time and date differs..). why is taht so and how to make it all the same?
see the attached file
imagedate format.JPG / V - Attached On 2017-03-22 16:10:03 UTC - Size: 80.82 KB - 339 views
[2017-03-22 18:07:32]
The problem is with how Excel is interpreting the data. Not with the data itself. You need to look at the actual text file to see the data format and you will see it is consistent.
