Date/Time: Sun, 12 Jan 2025 23:57:00 +0000
Space between days
View Count: 757
[2017-03-22 15:58:05] |
Robson - Posts: 76 |
is there a way to increase space between days for intraday bar charts?
[2017-03-22 16:11:14] |
Sierra Chart - Max - Posts: 5778 |
You can change the spacing between bars. Refer to Changing Bar Spacing: Working With Charts: Changing Bar Spacing To add separation between different days on a Chart, you can also use the Vertical Grid option: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support |
