Date/Time: Mon, 21 Apr 2025 23:27:28 +0000
Global Change of Horizontal Lines in Studies
View Count: 1010
[2017-03-22 08:14:50]
User186889 - Posts: 54
Hello Sierra
The Chart Studies option - 'Horizontal Lines' - defaults to Lime Green, which is OK on a dark background but rubbish on a white one. Is there any way I can either (a) globally change all the lines to a particular color, line type and width thickness? or (b) do it at the study? - At the moment I have to individually change each line which is very laborious as I use the lines for my levels and there are many charts. I have tried the Global Settings >> Graphics Settings and find no option to do this.
Thanks - Mark B
[2017-03-22 18:33:46]
You can change the default for all of these Subgraph settings for any new instances of the study added. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#CustomDefaultStudySettings
Existing study instances have to be manually changed one by one.
Date Time Of Last Edit: 2017-03-22 18:46:28
[2017-03-22 18:47:02]
We will add a new Input to the Horizontal Lines study to make all of the Subgraph visual settings the same as the first one.
[2025-02-13 20:45:16]
User708340 - Posts: 12
The function has been added "Horizontal Lines at Increment" study too. Instead of changing color and line style one by one, you can
Change "set all Subgraph Display Settings to be Same as First" as YES!
Date Time Of Last Edit: 2025-02-13 20:54:26
