Date/Time: Wed, 15 Jan 2025 21:57:24 +0000
Default Data Feed
View Count: 791
[2017-03-22 01:12:04] |
User140492 - Posts: 1 |
I used to use CQG feed in SC, but have changed to Rithmic. When I start the SC program, it always tries to connect to the old CQG feed. I had taken the user:pass out of that feed's fields in the Data/Trade Service Settings, but still, its going for CQG instead of the Rithmic feed. How can I default Rithmic to be the default feed? |
[2017-03-22 01:25:35] |
The automatic setting of the Service to CQG has been removed.
[2017-08-29 20:24:12] |
User918868 - Posts: 1 |
I have the same issue as this. Can you please remove CQG? Thank you |
[2017-08-29 20:57:51] |
Done.
[2017-09-20 19:51:30] |
User742056 - Posts: 5 |
Hi There, I also have this problem. I'm trying out another feed yet SC continues to default to the now-cleared CQG feed. Would you mind helping me out on this @Sierra Chart Engineering Thanks for your help & patience! Date Time Of Last Edit: 2017-09-20 19:54:56
[2017-09-20 19:58:31] |
We have now disabled the automatic setting of Service Settings for your account.
