Date/Time: Sun, 12 Jan 2025 23:58:52 +0000
Can I make the trading dom smaller vertically without the levels squishing together
View Count: 1123
[2017-03-21 21:40:17] |
User48557 - Posts: 138 |
I would like to make my Dom smaller as you can see in the picture. The problem is that the levels squish together. Is there a setting so I can keep the dom levels consistent while making the dom shorter vertically
[2017-03-22 02:26:25] |
After you resize the window use this command to rescale the prices: The Chart DOM Scale: Auto Scale the Chart DOM The documentation also explains how to expand and contract the scale. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
