Date/Time: Sun, 12 Jan 2025 23:34:05 +0000
Connecting to Multiple trading providers
View Count: 604
[2017-03-21 20:51:59] |
Adam - Posts: 141 |
Sorry if this is a dumb question I have LMAX via DTC (set up in my account) and CQG. do i need two separate installations or can i use a sub instance? Thanks |
[2017-03-22 02:12:26] |
You need 2 separate installations. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-24 11:25:44] |
Adam - Posts: 141 |
Cheers
