Date/Time: Sun, 12 Jan 2025 23:29:55 +0000
Transfer alert sounds file to new pc
View Count: 945
[2017-03-21 19:30:23] |
User360283 - Posts: 506 |
I have many custom sounds in my saved alerts sound file. How do I get my file into Sierra Alerts without having to do each sound file one at a time? Thanks |
[2017-03-22 02:14:02] |
The sound files are contained in the AlertSounds subfolder. Those can be copied from one installation to another. The global Alert Sound configuration is contained in the Sierra3.cfg file. For more details, refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
