Date/Time: Sun, 12 Jan 2025 23:39:34 +0000
New desktop
View Count: 623
[2017-03-21 16:04:27] |
User97684 - Posts: 136 |
Hi , My old desktop is dead since more than a week ago. I got a new one and downloaded a new copy of Sierra, installed it and connected on my live account. I have a backup of all my Sierra files from my old computer on an external drive. Pls help with these: 1. How to put all of my original chart books onto the new desktop ? 2. How to make the settings I had from the old copy of Sierra appear on my new copy on my new desktop ? 3. Will there be a problem with a clash of duplicate sierra copies for the same account - i.e. me ? Many thanks, best v |
[2017-03-21 16:31:30] |
Sierra Chart - Max - Posts: 5778 |
1,2. Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation 3. No, you will not have an issue with your Sierra Chart account. Sierra Chart Support |
[2017-03-21 17:51:11] |
Let us know if you need more help and if help topic 15 is clear in regards to this.
