Date/Time: Sun, 12 Jan 2025 23:57:49 +0000
Order cancellation failed
View Count: 768
[2017-03-21 15:42:38] |
nicktrader - Posts: 727 |
What does that message mean? I work with attached orders Order cancellation failed | Order Cancel Reject. Text: The order was in a state that prohibited a cancel request. Internal Order ID: 4339. Service Order ID: 1058746020. Symbol: F.US.DBM17 | 2017-03-21 16:38:39 * |
[2017-03-21 17:31:27] |
We need to ask CQG about what this means.
[2017-03-21 17:48:18] |
According to CQG the order did get canceled but what happened is you canceled it twice and the second cancellation got rejected.
