Date/Time: Tue, 14 Jan 2025 12:00:52 +0000
Real-trade data
View Count: 1046
[2017-03-21 15:37:48] |
User659433 - Posts: 13 |
I want to practice stock (NYSE, NASDAQ) trading with real-time quotes (without funding). What Sierrachart data-feed do I need to buy? 100Stocks enough.
[2017-03-21 16:37:27] |
Sierra Chart - Max - Posts: 5778 |
You would need the Standard Sierra Chart Package . And you will need to activate the Sierra Chart Real-Time and Historical Exchange Data Feed with the U.S. Equities (NYSE, NASDAQ, AMEX, BATS) Exchange. Refer to: Sierra Chart Exchange Data Feed Sierra Chart Support Date Time Of Last Edit: 2017-03-21 17:12:04
[2017-03-21 17:35:07] |
So the data feed will cost 1st connection 35 USD/month + 10.5 USD = 44.5 USD? Plus 24USD Standard Sierra Chart Package?
[2017-03-21 17:40:01] |
Yes this is correct in regards to pricing.
[2017-05-04 15:49:36] |
i cannot activate neiteher U.S. Equities (NYSE, NASDAQ, AMEX, BATS) Exchange nor BATs Exchange. The Balance is charged to activate.
[2017-05-04 16:29:24] |
The following message "To enable this exchange, you first need to sign the agreement and then activate the exchange." is shown by every exchange option. You first need to complete the agreement here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Agreements Continue with Step #7 here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-19 08:17:23] |
Where I can check the date when my 14 days test period of realtime data feed ends? Is it today or I can still use today?
[2017-05-19 12:53:33] |
When the data feed is active you can see that here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures However, the data feed is now expired as of 2017-05-18. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
