Date/Time: Mon, 25 Nov 2024 07:27:14 +0000
trade dom columns
View Count: 1665
[2013-04-02 19:11:42]
tr726 - Posts: 30
is there a way to adjust the width of the trade dom columns?
[2013-04-02 19:13:17]
Select Global Settings >> Chart DOM Settings.
[2013-04-04 15:45:26]
tr726 - Posts: 30
ok and then?? i would to narrow the width to the price column on trade dom (there's a lot of unused space. also how can i change the column width on the volume by price on the trade dom??
[2013-04-05 01:42:31]
The reason for the delay is we needed to work on documentation for this (See below). You cannot control the width of the price column. That is a little wider than it has been before based upon user feedback.
The Volume by Price width is controllable through its Input settings:
http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings
Adjust the Maximum Volume Bar Width Percentage input.
Buy / Sell Column Minimum Character Width
The default setting is 0. This means the width of the Buy and Sell columns on the Chart DOM or Trade DOM is automatically controlled. Setting this to a nonzero value specifies the width in characters, based upon the selected Font Size for the Chart DOM or Trade DOM, that the columns will be at least as wide as. They will be widened more if necessary based upon the order quantities displayed.
Date Time Of Last Edit: 2013-04-05 01:43:11
[2014-01-24 20:58:14]
User40526 - Posts: 166
I would like to be able to increase the font size on the trade dom buy/sell columns. The font for the price ladder is larger and easier for us old guys to see. Increasing the column width does nothing for the font size. Thanks
