Date/Time: Sun, 12 Jan 2025 23:41:21 +0000
MACD Diff Color Change
View Count: 817
[2017-03-21 15:20:24] |
JayShea - Posts: 92 |
Hello I'd like to show the MACD Diff when it's above Zero based on Slope. In addition, I'd like the same when the Diff is below Zero. However, I'd like the two colors UNDER Zero be Different from the colors ABOVE Zero. Is this possible? Thanks JD PS Attached image of all I can figure out. |
[2017-03-21 17:53:05] |
The only way to do this advanced coloring logic is to use multiple instances of the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-21 17:54:08
