Date/Time: Sun, 12 Jan 2025 23:46:49 +0000
True range without gaps
View Count: 657
[2017-03-21 07:43:04]
EuropeanTrader - Posts: 290
is there a way I could see the actual true range of these bars (session times applied to one 30min bar) without gap affecting the calculation?
http://www.sierrachart.com/image.php?Image=1490082116782.png
Thanks!
[2017-03-21 17:17:49]
You need to use the True Range study:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s346
[2017-03-22 08:29:33]
please see attached.
Bar A vol is smaller than bar B's.
Indicator below takes into account the gap.
Is there a way to avoid that, please?
Thank you.
imagesc.png / V - Attached On 2017-03-22 08:29:30 UTC - Size: 80.26 KB - 259 views
[2017-03-22 09:58:16]
Is there any way to avoid what specifically? Also the True Range study does not use volume in any way.
[2017-03-22 14:52:39]
Sawtooth - Posts: 4149
Use the Study Subgraphs Difference study,
set the Input Study 1 to High,
set the Input Study 2 to Low,
set the Draw Zero to Yes.
