Date/Time: Mon, 13 Jan 2025 02:22:43 +0000
Uni renko charts
View Count: 3447
[2017-03-21 03:02:17] |
User157806 - Posts: 71 |
Hello I am trying to assist a customer with the following inquiry customer is using uni renko charts on NinjaTrader as well as on Sierra Charts but they are seeing two different charts and would like to know the reason why? See screenshots attached for reference for both NT and sierra charts and also the settings and parameters for both charts.
unirenko 1.png / V - Attached On 2017-03-21 02:59:57 UTC - Size: 70.07 KB - 1414 views sierra uni renko.png / V - Attached On 2017-03-21 03:01:13 UTC - Size: 37.72 KB - 998 views NT renko settings.png / V - Attached On 2017-03-21 03:01:32 UTC - Size: 45.42 KB - 1033 views sierra settings renko.png / V - Attached On 2017-03-21 03:01:55 UTC - Size: 62.71 KB - 932 views |
[2017-03-21 03:28:59] |
The Universal Renko settings in Sierra Chart need to be: Bar Size-2-6 So you need to determine what the Bar Size in ticks should be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-23 22:43:37
[2017-03-22 01:59:27] |
Appreciate it thank you!
[2017-03-22 02:06:48] |
Sorry just want to make sure before I inform the customer per your response should it be applied as this in the attachment?
sierra charts-renko settings.jpg / V - Attached On 2017-03-22 02:05:07 UTC - Size: 158.91 KB - 666 views |
[2017-03-22 02:25:04] |
That does not look right. Do you know how many price ticks the Renko bars are from the open to close in that ninja chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-22 02:38:50] |
Let me verify with the customer. Thank you.
[2017-03-23 04:16:30] |
User150371 - Posts: 70 |
To get the equivalent of those Ninja Unirenkos in SC, I have used Universal Renko 4-2-6 . I have also used Flex Renko 4-2-2-x. I'm not sure which comes closer to the bars in Ninja. |
[2017-03-23 04:18:23] |
Universal Renko 4-2-6 seems reasonable.
[2017-03-23 22:43:09] |
Therefore, in this case you will want to use 5-2-6.
[2017-03-27 02:54:27] |
No, Sierra Chart does not have this study.
