Date/Time: Sun, 12 Jan 2025 23:34:54 +0000
User Question
View Count: 706
[2017-03-21 00:46:49] |
Sierra Chart - Max - Posts: 5778 |
one set of candle January 3 clears the peak of
December 12 and the second set doesn't. Which settings are correct ? which volume should be set : Volume Based Rollover or Volume Based Rollover Back Adjusted On which Time Frame ?? One of the picture is Volume Based Rollover and the second is Back Adjusted Sierra Chart Support |
CLK7 [CBV] Daily #6 2017-03-20 17_46_54.756.png / V - Attached On 2017-03-21 00:46:19 UTC - Size: 107.84 KB - 284 views CLK7 [CV] Daily #6 2017-03-20 17_47_45.743.png / V - Attached On 2017-03-21 00:46:27 UTC - Size: 97.84 KB - 259 views |
[2017-03-21 03:26:19] |
For accurate prices you definitely do not want to use one of the Back Adjusted Continuous Contract settings. Also refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
