Date/Time: Sun, 12 Jan 2025 23:29:47 +0000
[Programming Help] - ACSIL: Draw rectangle using highs
View Count: 937
[2017-03-20 19:49:56]
phaedonk - Posts: 352
I'm using two instances of the swing high/low indicator. So, if I'm not mistaken, I should have two arrays of swing highs: an HTF one (let's say 40 bars) and an LTF one (10 bars).
How could I use ACSIL to draw a rectangle from an LTF high to the HTF high that was created after it?
Any help or tip is appreciated as I'm new to ACSIL.
[2017-03-22 15:33:21]
Anyone?
[2017-03-22 17:52:56]
This is marked as Programming Help and is not within the scope of our support. We can refer you to a programmer. Let us know if you want us to do that.
[2017-03-22 17:57:36]
I marked it in order to not waste your time. I was expecting an answer from the community.
Of course, you could chime in with a hint if you wanted. :)
I will not be seeking help from a programmer at this point.
