Date/Time: Sun, 12 Jan 2025 23:49:35 +0000
Number of Rows Spreadsheet Study
View Count: 792
[2017-03-20 19:02:13] |
User12089 - Posts: 361 |
What is the exact Number of Rows supported when using the SC Spreadsheet Study And what is it when using recent editions of external Excel which support 1 million rows I have noticed that export from SC fails/freezes well before 1 million rows are specified so what are the exact thresholds in each of these two separate cases |
[2017-03-20 22:42:00] |
system config - 32 GB RAM, 4 core CPU, single SC instance with only 1 chart loaded and no other apps running - so system resources are not a/the problem
[2017-03-20 22:54:01] |
You will have problems when using Excel and we do not provide support for those issues. In the case of the Sierra Chart built-in Spreadsheets, the number of rows supported is 1048576. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
