Date/Time: Sun, 12 Jan 2025 23:35:21 +0000
BackTesting Using Spreadsheet System of Trading
View Count: 683
[2017-03-20 13:11:55] |
User299392 - Posts: 216 |
I am trying to use limit buy orders but cannot figure how to get a buy limit order price since the only space to indicate that price is a cell in the J column and essentially, I wish to suggest the system to buy 2 ticks below the current prevailing bid at the time of condition fulfillment in column K3. I am fine with non-fills but in cases with fills; I wish to test my system. Please. Please help! |
[2017-03-20 13:40:09] |
Sawtooth - Posts: 4149 |
Try this in J22: =J12-J21*2 Also, J71 must be set to 'L' Date Time Of Last Edit: 2017-03-20 16:57:07
[2017-03-20 17:34:01] |
You can use a formula in these cells to set the limit order price: http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#LimitPrices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
